I got the 93 J30 , and similar things like that ending with no starting in a couple of weeks. So it was an
"intermittant " problem , ended up being fuel starvation due to , as in both our OLDER vehicles, fuel pump relay -hidden behind drvr's kick panel , brown colored and paired with a "tailight -bulb-out" relay on a bracket and behind that silver sound-matt stuff. Contacts became more & more marginal till it wouldn't conduct enough current yet, it DID CLICK OVER- closed position ! Hearing it energized & clicking I almost overlooked - but as a professional electrician , a couple of further tests of the f/pump ckt I went back to relay upon getting virtually NO current flowing through the closed contacts.
Other than removing kick panel , and I believe some module , then the matting , and relay cost me $16 - it's a relatively clean and easy repair , better than "shotgunning" a ton of engine sensors ,IACV,MAF ya know. So ,kinda
hope you got what I had !
But CHECK ANY CODES first.
