Weird RPMs... Happening to you?
indus49
Car: 2007 Nissan Versa S, Magnetic Gray with Beige/Black Interior, Power Package.
I take the highway for part of my commute, and noticed something strange. I leave my house, and within a couple of minutes I'm on the highway, going about 70. My RPMs at this point are about 3,000, maybe a little over.
In another 3-4 minutes, my car decides to calm down, and now it only takes 2700 RPMs to keep my car going the same way...
Could this signal an (impending) problem with my transmission? Or is this just the engine/transmission finally warming up? Has anyone noticed this type of behavior? I have the 4 AT.
Ever Victorious
Car: '08 Kia Spectra 5
'73 AMC Hornet
The torque converter on my old Kia would do that... it would take a while for the transmission to finally realize I wasn't accelerating anymore and engage the gears as opposed to... well, whatever the hell an automatic does.
(Any wonder why I picked the 6-speed?)
proxim2020
When I was younger, my mom had a Hyundai that would do that. The little car would roar down the highway for about 5 minutes and then quiet down. The transmission wasn't realizing that the user wasn't accelerating anymore and would stay in it's current gear. Even if you took your foot off the pedal completely. She didn't bother with getting it fixed because she didn't want to pay $500 in diagnostic charges.
skoobahead
Car: Powder 1.8SL CVT
Strange...Sounds like an electronic transmission issue.My CVT is turning at 2400 RPM at 70 mph. RPM's steady as a rock.
Jrscherer
Car: 2007 Nissan Versa S 14000 miles.
I've had the same thing, it's either that it doesn't get that it isn't accelerating, or it's the fact that it's finally up to true running temperature which is one thing I kinda with the Versa had, a normal temp gauge. Oh well, guess I'll just need to get used to it.
BenDupre
Car: 2007 Versa SL w/CVT, 2006 Quest 3.5
It's not the transmission, it's the torque converter. It's taking a while to "stall". My Sable did this also.
A torque converter allows the flywheel and transmission to spin at different speeds, the way a clutch does, but using hydraulic fluid and a turbine instead of a disc and pressure plate. It's designed to "stall" once the car gets up to speed. When you see the engine turning 3k RPMs, the torqueconverter is still slipping. When you see it drop down to 2700, it has "stalled" meaning the flywheel and transmission input are turning at the same speed.
I'm not 100% sure whether it's a problem or not. Ideally, the converter will stall quickly when you reach speed, or even before. It should slip only when the engine doesn't have enough torque to turn the transmission. When it's not stalled, it's wasting energy. Which is the main reason why manual transmissions are more efficient than automatics.
Ask your dealer about it. But be prepared to get the line that "that's normal". I really don't know how you will get an honest answer, mechanics are almost as honest as salesmen.
Any mechanics out there who aren't insulted by my comments want to give an opinion?
Ben
SVersaS
Car: 2007 Nissan Versa 1.8S
i have a 4AT also and i havent noticed anything like that. whenever i reach 70, im steady at 2900 RPMs always.
skoobahead
The" lock up" function of the torque converter is controlled electronically is it not?
LA02MAX
Car: 2002 6-speed maxima
Yeah that's pretty much normal for all of the new cars with conventional autos. It's a feature that supposedly allows everything to get to operating temperatures quicker...My mom's '00 maxima 4AT does that when you first get up to speed and usually about 5 minutes after it seems to settle down. It's almost like it disengages O/D for the first 5 minutes....
BenDupre
Skoob,
It's not electronic. It's fluid dynamics, plain and simple. The technology has been 'round since the 1950s.
Ben
skoobahead
Hmmm...I guess things have changed since the 50's
"Carmakers took the torque converter one step further by adding a lock-up function beginning around 1980. Lock-up converters also contain a friction clutch that locks the converter impeller to the turbine, usually in higher gears. A solenoid-controlled oil passage, commanded by the cars powertain control module (PCM), locks and unlocks the converter based on driving conditions."
Modified by skoobahead at 7:15 AM 10/12/2006
indus49
Great... well as long as this is normal, I can deal with 5 minutes of inefficiency I suppose... This is my first AT, I used to drive a stick... Did I make the right choice?
Ever Victorious
'73 AMC Hornet
indus49 wrote:Great... well as long as this is normal, I can deal with 5 minutes of inefficiency I suppose... This is my first AT, I used to drive a stick... Did I make the right choice?
No
But that's just me.
BenDupre
I agree with EV. IMO small engines don't have enough power to waste. Manual is the way to go.
Of course, I have a CVT and I love it. I would have gone with the 6sp if it wasn't geared so short. I like cruising at 75 mph with the enging purring at 2500 rpm.
Skoobahead,
Not all torque converters have a lock-up clutch. I guess I don't know for sure whether this one does but I suspect not.
Ben
skoobahead
No way!
Unless your driving a performance car.... go with the auto. Rowing gears in the Chicagoland area wears you down quickly.In addition, CVT highway cruising at 75MPH with tach only turning at 2500rpm rocks
My .02
proxim2020
skoobahead wrote:No way!
My .02
It's a matter of preference more than anything. Either you will enjoy shifting gears or you won't be a huge fan of it. Either you're going to enjoy not having to worry about gears while driving or be constantly upset because the car's picking the gears for you that you don't necessarily want to be in. The Versa isn't a performance vehicle, but it can be. You just have to throw $ at it. Buy what's right for you (auto or man).
hoangmn
Car: Versa 2007
When you start your car, wait for the blue thermo icon off before you start driving. That's when you car is at optimal temp to operate. The car is computer control so temperature and other conditions will be calculated to make the engine work best.The SL with CVT is even more sensitive to these conditions. You have to pay more attention or your transmission will break sooner.
BenDupre
hoangmn wrote:The SL with CVT is even more sensitive to these conditions. You have to pay more attention or your transmission will break sooner.
skoobahead
Hmmmmm
