Weird REAR Vibration/Shaking M35..
tolete212
'06 M35 Rear shaking when hittin 50 mph and up...the faster i go the stronger it gets. when i brake doesnt shake like if was the rotors so i believe the rotors are not the problem its only when i hit the gas.
and i checked the hub bearings too they're perfect and rims are perfectly balanced... what could be the problem??? the differential? idk help/// forgot to mention i did cut a layer on my rotors.
M35 Sport
Car: Infiniti M35 Sport
On a rear wheel drive car you could have and out of balance drive shaft. Your wheels and/or tires could still be a problem also. Were your wheels just spin blanced or road froce balanced. A bent wheel will sometimes still spin balance fine. How do you know all of your wheel bearings are fine?
tolete212
i guess the bearings are fine because theres no sound coming out of it..theres a clicking sound when i put the car in Reverse.
M35 Sport
tolete212 wrote:i guess the bearings are fine because theres no sound coming out of it..theres a clicking sound when i put the car in Reverse.
I would still check on the bearings. I found out you can have a busted (out of alignment) bearing with no moaning noise. This happened with my last car 2004 pontiac Grand prix.
tolete212
lets see what my mechanic says today...ill have that in mind. thanks
papaupa212
Car: M35
hey im having the same problem, 50mph and up the car start to shake...i checked the wheel (all 4 balanced and not bent)
you think it might me the drive shaft?
mgokool
Car: 2006 M35x
Had this problem when I had my 06 M35x...the problem for me turned out to be a frozen rear caliper...replaced the caliper and solved the problem...
