Weird rattling/shrieking noise at 1900rpmsh
Dazzla
OK, guys this is my problem.
http://www.courtesyparts.com/2....html
Part 20515, and Part 20510...the exhaust tube insulators around the downpipe. Can I just take these off? But won't it heat up my drivers area like hell
Modified by Dazzla at 12:10 PM 10/18/2009
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Heat shield rattle, broken cat screen, timing chain guide. Try to pinpoint the area better
Dazzla
OutToWinPAHC wrote:Heat shield rattle, broken cat screen, timing chain guide. Try to pinpoint the area better
Ok i've been looking around and trying to narrow it down...its definitely nothing to do with the timing chain guides because the sound seems to be coming from downpipe area. I jacked up the car and everything seems fine.
The sound seems like a vibration noise where something is hitting something else. Happens at about 3k rpm if I'm revving it at a stop, happens all the time if I'm driving. Its not my exhaust, the sound is coming from the area before the cat...maybe header and downpipe need replacing lol
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Are all the manifold bolts still there, and torqued?
Dazzla
hmm will check that...could it be motor mounts?
Koshin
Car: JP'd out Y32 Nissan Gloria GTU
750 hp '87 Buick Grand National
'63 Chevy Impala SS 327/4 speed
what he said...check your manifold studs to make sure they are tight as well...
is this a KA or what?
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
my vote is the shell of the cat on the down pipe. mine was rattling for a while. i fixed it with a big hose clamp. no more noise.
numbnuts240
2011 Ford Focus
2010 Mazda 3
Koshin wrote:is this a KA or what?
Dazzla wrote:Everything is pretty much original its a 1995.
Dazzla
How do I even get down there? Lol jack up the car from the engine throw two jackstands? or can I access that from teh engine bay?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Yeah....... you need to get under the car. Unless you got go go gadget arms.
Two Fowty
Car: 1990 240sx hatch, 1989 240sx hatch
definately your heatshield.. even one loose bolt can cause it. mine does it at exactly 2k rpms in any gear. mine is up where the header ends and the first heat shield is there.. i have all but one bolt in and it makes the noise..
Dazzla
Heat sheild is that fugly looking cover on the headers right?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
and cat
Dazzla
Oh ok, so that shouldn't be too difficult. I should be able to get it out of the engine bay right?
Any negatives if I drive around without a heat sheild? Other than more heat in my feet area?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
dont submerse the bottom of the car in puddles. Headers can crack, but I have taken them off a few of my cars, nothing to worry about.
Koshin
nah, dont worry about jacking the car up y0
Dazzla
One more thing if I take the sheild off what happens to the o2 sensor thats plugged into the sheild? Just leave it hanging? lol
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
the 02 goes into the header / pipe / downpipe, not "into the sheid" The shield sheilds the pipe.
Dazzla
ok so I checked the heat sheild...one bolt missing and one was loose. tightened everything up and drove it, I had alot less of the rattling sound but its still a little bit there
fourLUG_hero
On my car my exhaust rubbed against my driveshaft at certain RPM's.
Dazzla
fourLUG_hero wrote:On my car my exhaust rubbed against my driveshaft at certain RPM's.
It does sit close, but my stock exhaust made the same noise, and so does my new Apexi lol so it can't be that
safin
i really like the stance of the 240 in your avatar
Dazzla
Modified by Dazzla at 12:09 PM 10/18/2009
Klits562
Car: white s13 coupe
a few people just told you that removing the heat shield wouldnt do anything to your car but you have to be careful for your heated exhaust piping if you hit a cold puddle rapid cooling of heated metal causes cracking or weakness.
