Weird rattle noise......
jhuerto23
Car: 2006 Infiniti M45
Alright, heres the deal. Whenever I drive over a messy road ie; pot holes, little cracks, bumps etc I hear rattling noise coming from what I think is underneath the car. I brought it into the local dealership and they said my ebrake cable is loose and thats the reason why I have to press down so far to apply the ebrake. It fixed the problem for a few days and then I start to hear it rattle again. I brought it back today they said they fixed it by adjusting the cable again. My wife picks up the car and says its fine, but I take it out for a spin to the gym and I hear the noise again. I have extended warranty, why don't they just replace the damn cable? What should I tell the service rep tomorrow?
Moon Man
Car: 2006 M45 Sport Aero
Tell them exactly what you typed here and tell them that you gotta busy schedule and are kinda getting upset that the problem isn't being fixed.
You did pay for the warranty so you have every right to demand a permanent fix not just quickie that's gonna be problematic.
djpeak10
Car: 2007 M35 Sport
This is what i do. Talk to your service advisor and ask to have a tech go on a ride with you. Show him first hand the noise, and then they will fix it whether it is your cable or whatever.
MRider
Car: 2006 M45
Mine was the the ebrake issue. They tightened it and noise went away. There are other post on this topic that mentions a Y-Pipe issue which could be your case if the tightening the ebrake did not work for you, jherto. Link to post here...
06-m45-sport-rattle-under-acceleration-t220421.html
chelubi
Car: 07 M35x which replaced 06 M45sport
Try driving down the road on which you know the rattle will occur. Roll down all windows so you can hear the rattle. When you do, with your left foot, press down a little bit on the parking brake which removes slack out of the cable. If the noise stops, it is your parking brake shoes rattling. Adjustment is under the dash on the top of the parking brake. There is a 12-13 mm nut. Your parking brake pedal should engage almost as soon as you depress it. It it goes 2-3 inches there is too much slack.
jhuerto23
Thanks I will look into it.
Cabo
Car: Infiniti M35 sport 2006
Nissan pathfinder LE 2002
Thanks to.this thread I fix that stupid annoying noise that I could never find hahhaha
m4m
Car: 2009 M35S
found following 2 tsb's Rattle issues:
Subject: SB 2006 - 2008 M; Rattle Noise From Top Corner of Windshield, Left or Right
Summary of ITB05020:
IF YOU CONFIRM A rattle noise coming form the upper corner of the windshield (left or right side). See this bulletin for further detail.
Subject: SB 2006 M; Rattle From Glove Box
Summary of ITB05045:
IF YOU CONFIRM There is a rattle or buzz noise coming from the glove box area And The rattle goes away if upward (closing) pressure is applied to the glove box door. See this bulletin for further detail.
HTH
Infinity_818
Car: 06 Infiniti M35 Luxury Edition, Journey Package, Tech Package, Black leather, limo tint.
I have just recently start hearing that rattling noise, it's like a loose chain the most I can describe it it comes from the rear of the car as soon as I put it in drive and take off at low speeds, I suspected it could be something related the E-brake cuz recently the pedal press is so far down. I will look into the suggestion the other OP stated where u can adjust the E brake from underneath steering wheel. I hope it works. I will repost once I find out.
