weird question
xiongbs13
Car: 1990 Nissan 240sx SE fastback, hard top 1990
How much do you guys think it will cost just getting my ka24e rebuilt oem style, but what i am talking about is, the cost of taking the head and the block to the shop and getting it cleaned out and then i will put everything back together myself and a friend that has been building SR's and KA's for 5 years now, but i got the rebuild kit for $380, it came with all gasket set, piston rings, pistons, FREEZE PLUG set, CONNECTING ROD BEARING SET, MAIN BEARINGS SET, OIL PUMP, TIMING KIT, PISTONS/RINGS: STD, .020, ROD/MAIN BEARINGS: STD, .010, .020, and if there is something i am missing then let me know, but i just want to know the price that the shop is going to charge me.
WDRacing
You'll have to answer that yourself by contacting local machine shops in the area. It may even be worth it to have them assemble the motor for you. There are things that need precision measurements, like piston ring gaps and rod end cap seats.
WD
