chmercer »
https://forums.nicoclub.com/chmercer-u5648.html
Tue May 09, 2006 4:57 pm
they arent welded on, if you take the hub all the way apart you can un bolt them, but nobody really does that.
alan im not "haterading"
there are tons of more important things to worry about on a car besides dust shields, im sure you know this
russell was sarcastic but my post was 100%
dust shields are included on stock cars to improve braking from when you park your car somwhere, and it rains, and your brakes are wet for like 5 minutes. im sure theres some kind of debris protection factor in there also.while you are driving there is like no chance for water to stay on the rotors.
so basically you are getting an increase in wet parking lot braking for an increase in rotor temps. sounds like a deal to me.
here is a gt500 r34 wheel well
there is no dust shield
is that good enough reason?
as for the breather filter comment, are you serious. NO turbo KA would run a hose from the intake to the valve cover. all that would do is pressurize your valve cover and screw stuff up. every racing series on the face of the planet requires cars to run oil catch tanks.
here is some rules for formula SAE that i turned up in 2 seconds on google
"The engine also needs at least one catch can. Any of the engine breathers, whether they are on the crankcase or on the cylinder head, need a catch can to catch any blow-by gasses, etc. If the engine is completely sealed with no vent, pressure within the crankcase will blow out crank seals, etc., dump oil on the track, and probably result in a wrecked engine. The hose into this catch can should stop near the top of the can, not go to the bottom. You do not want any of the debris that might have come over from the engine being sucked back into it as the engine cools down."
since you seem so enamored with 80s passenger car technology, care to tell me why retaining the pcv system in all its OEM glory is so crucial to the proper operation of our cars? because i cant find "a damn good reason for it".
basically its an emissions device. all the thing does is open a valve when the motor is at running speed to use vaccum to pull blow by gas into the intake tract. it makes much more sense to put that gas into a tank, or into the air (your air breather example). obviously if your motor is older and has larger gaps between the rings etc or you are running boost with higher than normal pressure you can get oil in that pcv hose, then you end up with motor oil going into your air intake. nobody has to be a genious to see that situation is not advantageous.
--- ANSWER ---to answer your question, the easiest solution i could think of to your dust sheild issue would be to get a z32 dust shield, cut out the center section that bolts to the hub (you would be left with only the outer part of the sheild, the part that does the actual splash protection) and pop rivet that onto your existing trimmed back shield. i would put the pin head of the rivet facing away from the brake rotor, the heads of the rivets have a lower profile and would give you less chance of rubbing on the rotor.--- ANSWER ---
it seems that a lot of you guys dont think i know what im talking about because i dont take the time to write out an essay when a simple 1 liner will do the job? whatever
Modified by chmercer at 4:37 AM 5/10/2006
