Weird Problem with CVT
All things Altima Coupe.
DiamondWVU
Car: 2.5
So the other day I was driving in manual mode. I was in "4th." Then all acceleration gave out. The indicator light which tells you what "gear" it is in or P R N or D started flickering. Went down to 3rd then 2nd then back to 3rd. The rpms were responding with the gears too. Then the indicator light completely went away. Turned it off for about 2 minutes and it didn't come back. Turned it off for another 10 minutes and it came back on. Got another 5 miles down the road and it happened again. Somehow got it home, turned it off over night then happened again about 4 days later. Anyone have any idea what is wrong? Not sure if it my transmission or a sensor or something. Any input will help.
Thanks
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
Didnt you just have your trans completely rebuilt from that mess with the audio install? Should have some sort of warranty on that.
Another new issue, Id get this into gen chat as well, might get some more help there.
