hm, I changed the one that looks like a blade connector, which I believe is the sender.nismotuner1 wrote:did you replace the coolant temp sensor or did you replace the sending unit? sensor sends signal to computer sending unit sends signal to gauge
Well, the original one I replaced was from checker auto parts, so I thought that it was possible that it was crap. so earlier today I went and bought a new one from napa and it had the same results...nismotuner1 wrote:the single blade one is the sender maybe you got a messed up one
well... the heat that radiates off the engine seems to be normal, doesn't seem like it's overheating... no smoke or anything out of the ordinary, but this only occurs when the car is put in gear and I start going.martins_240sx wrote:is the car actually getting hot...smell hot?
hahahaha... didn't even notice that lol.yeah I was probably just going to get an aftermarket gauge.livinglegend2100 wrote:nice toes
but really, find someone with an aftermarket gauge, or just another 240 cluster and hook it up. definitely electrical
