clovers525e »
https://forums.nicoclub.com/clovers525e-u47904.html
Thu Aug 23, 2007 1:14 pm
alright, i spent a whole day f-in with it. i did a compression check a second ago and it read 150 across all cylinders and held compression fine. the compression checker i used was a little off, reading about 20 psi with no pressure, so i'm guessing 130-140 across all cylinders. with my compression checker, which also seems to be screwed up, it bumped up to 90 psi but the checker isnt holding compression. when i had the ka s14 maf installed i remember that it idled fine, it just didnt rev well at all, so atleast i know it can be done. i changed out my o2 sensor for one i baught as a replacement for the old ka motor but it didnt change anything, i took off all my intercooler piping and ran the shortest way i could but it still didnt improve. undid the tps and fiddled with it but it never improved, same with the cas but nothing. replaced the water temp sensor, nothing. \so, in the end i'm still where i started. my multimeter crapped out on me today too, so i couldnt acthually check the tps signal and the maf signal so i guess when i get payed again i can try to fix it or go buy another, along with a new compression gauge and then i'll have a better idea. i switched out the maf sensor i got from a junk yard for one a guy had down the street, no change.... so i'll have to wait unless someone else has any more ideas.... o2 sensor maby? spark plugs? maby both maf's are bad?
i'm going to post a vid on utube and put up a link so maby someone will be able to better help me, along with looking at the vacume its pulling, btw, what bar of vacume should i be reading? boost gauge started working today
coupedup, how do you check the timing on these? i'm used to plug wires thanks for the help btw
