biosehnsucht »
https://forums.nicoclub.com/biosehnsucht-u13953.html
Thu Apr 14, 2005 4:13 pm
mine used to be ok, but it was otherwise running badly.
then I fixed the fuel pressure, now its almost impossible to cold start (and its gotten worse!)
I thought it was fixed w/ the vacuum delay gizmo but I guess it was just already warmed up still (despite sitting hours) and thus worked fine then.
Granted once warmed up while it still barely maintains idle (roughly) it's doing it at the proper RPM not almost stalling.. and when I get over 2k it pulls HARD, but below it it barely moves.. :/
It's worse after I reassembled the intake piping after putting in the koyo and fixing the heater hose that was leaking, so I'm htinking maybe I don't have something on tight enough..
