Pat S »
https://forums.nicoclub.com/pat-s-u4002.html
Sun Jun 29, 2003 6:02 am
You know, I was driving the car tonight and I tried an experiment. While in D w/engine running, I turn the key to the start position. The A/C goes off and the starter does not engage. So, I think that there is a lock out relationship between the A/C, and starter in wiich the A/C is disabled when starting to lessen the load on the starter.
So, I am thinking that the problem may be in the ignition switch assy. , but necessarly the lock. I plan to call Scottsdale to check on availability of the switch.
Thanks for the help Jberger!
