weird pop when turning.
mofeel
Car: red 1990 Nissan 300zx n/a 2+2 5spd. sold
1993 nissan 240sx fastback 5spd. sold
2000 gc8 Impreza 2.5rs coupe. daily
1974 260z. project
hey guys wats up? i jus recently got a 93 240sx and i noticed when i turn so far left or right itll make a weird popping sound and then pull that way. itll even do it if i hit a bump sometimes. its got a set of coilovers on it i dnt kno the brand n the po didnt have much knowledge on the suspension due the fact the po was a girl. ne help guys?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Bet bet is go get under there and check everything. Chances are there is a loose bolt, or a shot bushing somewhere. Is the pop in the rear? I would check all arm bolts/nuts, check subframe bushings and bolts, differential bolts and nut, ball joints, rod ends, and the tension rods. When was the last time the bushings were lubed?
mofeel
1974 260z. project
ah its in the front. i heard sumone say a rack&pinion but its on the outer side by the tire is where the pop is coming from. n i dnt think its a balljoint cuz there isnt ne speed wobble lol. yea ima get under neath it when i get the chance to. ill do all that when i replace the ps pump cuz its whining jus a tad.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Rack bushings could be shot.
krash
Have this same problem on mine. Turns out that the spring isn't mounted properly on my Driver's side strut and the mount is also shot. Jack up the front of the car so the wheels are off the ground, take of the wheel, and have a friend turn it all the way to each side. Check out the struts while thats happening.
mofeel
1974 260z. project
aiight ill prolly check it out today since im goin to my dads n he has a gargae, gotta check out where my hatch is leaking too lol
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Probably the tail lights
mofeel
1974 260z. project
yea thats wat i was thinkn cuz the puddle was in the spare tire hole n theres a new gasket around the window.
mofeel
1974 260z. project
costa_rican13
Car: 1993 s13 coupe
the sealer nissan uses for taillights is called strip caulk made by 3M.
ricers1
Car: 1990 240sx
prob strut mounts frozen a bit. happens alot. that pop is the spring shifting around
ZombieWolf
Car: 1992 240sx
ricers1 wrote:prob strut mounts frozen a bit. happens alot. that pop is the spring shifting around
+1, my coilovers make a springy kind of popping sound when it gets cold out, if its that then dont sweat it.
By the way is there any way to prevent this? I hate having people in my car saying "what the hell was that?!" and all i can say is, "ehh its normal"
krash
yup! how'd you fix it? new mount?
mofeel
1974 260z. project
costa_rican13 wrote:the sealer nissan uses for taillights is called strip caulk made by 3M.
thanks bro i foundt a box for $15. ill get it n try it out n see if the leak stops.
mofeel
1974 260z. project
should b able to lube it up a lil right? lol or get a new one.
costa_rican13
Car: 1993 s13 coupe
no problem, i had the same problem. and i called the dealer and thats what they use, so i went there and they gave a big stack of it because i couldnt find any at my local auto stores.
charat
Car: 1992 Nissan 240sx SE, 2008 Honda civic EX
mofeel wrote:hey guys wats up? i jus recently got a 93 240sx and i noticed when i turn so far left or right itll make a weird popping sound and then pull that way. itll even do it if i hit a bump sometimes. its got a set of coilovers on it i dnt kno the brand n the po didnt have much knowledge on the suspension due the fact the po was a girl. ne help guys?
lol way to be sexist... lol :bigthumb:
anyways, it could be a lot of things. did you check your alignment? is your body straight? my friend had the same problem in a mbenz and it was her alignment... turns out she hit a curb going pretty fast... lol.
mofeel
1974 260z. project
damn lol but no im not sexist its jus a majority of women dnt kno a thing bout a car other than pushing the gas pedal n the brake lol
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
The same thing happens to my s13 when i turn. Nothing major, just annoying.
nismobenzo
Car: 240sx
if not your springs, it could be your ball joint? mine popped when it was going out
driftneil
Car: A pile of cars.
OK I'm going to blow everyone's mind......It is your tension rod busing......Guaranteed
Steady_One_S13
ooh. Will check.
driftneil
Steady_One_S13 wrote:ooh. Will check.
Had the same problem, the previous owner jacked the car up all the time with the tension rod. It will also blow from drifting
mofeel
1974 260z. project
thanks ill check it out. n the window is leaking on the hatch not the tail lights. my fiance felt cold air coming in last nite thru the hatch n put her hands by it n felt it.
nismobenzo
Car: 240sx
mine leaked through the antenna..whoda thunk it ha
mofeel
1974 260z. project
lol thats weird.
mofeel
1974 260z. project
well the pop was the tension rod bracket. it was bent. n discovered a small part of the frame is missing as well. wtf.
driftneil
mofeel wrote:well the pop was the tension rod bracket. it was bent. n discovered a small part of the frame is missing as well. wtf.
Winner! And what part of your frame is missing?
mofeel
1974 260z. project
driftneil wrote:OK I'm going to blow everyone's mind......It is your tension rod busing......Guaranteed
bushing was fine. the bracket was bent a lil n i straightened it up n it went a way for a lil bit n started back. im thinkn it maybe the ball joints tho.
mofeel
1974 260z. project
o and it wasnt the frame missing it was the plastic piece on the bottom that u take out for a cai
