weird overheating
roger75
Car: 1991 nissan 240sx
hey everyone i have a nissan 240sx which i recently changed the water pump and the thermostat...the weird thing is that when i accelerate the needle goes down to cold but the more i stop the more the needle goes to hot and it gets to the point to where it starts throwing steam out the overflow tank...anyone know what it can be?
xX RB Xx
Car: SE3P, FC3S, FC3C.
did you make sure everything was plug back up correctly?? and did you put coolant back in?
driftneil
Car: A pile of cars.
Air in the system
janda240sx
Car: 1995 240sx se
Last one I had that done that; it wound up being a blown headgasket.
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Head gasket or clutch fan.
driftneil
Wouldnt the h.g. make it overheat?
blacksrjdm
driftneil wrote:Wouldnt the h.g. make it overheat?
Steam comming out of the overflow tank...nah thats not overheating, thats just steam.......Huh???
A h.g. would make it over heat and that is exactly what is happening. Thanks though.
blacksrjdm
roger75 wrote:hey everyone i have a nissan 240sx which i recently changed the water pump and the thermostat...the weird thing is that when i accelerate the needle goes down to cold but the more i stop the more the needle goes to hot and it gets to the point to where it starts throwing steam out the overflow tank...anyone know what it can be?
The real question is why did you replace the water pump and thermostat? What was the symptom that made you replace those parts? We'll start there, that way we can see if the water pump and thermostat helped anything.
driftneil
Is there a need to be a d!ck? Didnt see the steam thing, my bad. Im having a similar problem, but when I start the car with the rad cap off, it pushes fluid out the rad. Also looks like it leaks from the water pump, so figured we had the same prob. Any suggestions?
3cpeeo
driftneil wrote:Is there a need to be a d!ck? Didnt see the steam thing, my bad. Im having a similar problem, but when I start the car with the rad cap off, it pushes fluid out the rad. Also looks like it leaks from the water pump, so figured we had the same prob. Any suggestions?
try this:
with the car cold, open the radiator cap and start the car. if it is pushing out the coolant out of the radiator, that is a blown head gasket. thats your exhaust stroke of your motor leaking out your radiator.
if it doesnt do that while its cold, the thermostat either got stuck closed already, or you need to bleed it. bleeding a system may take up to an hour, no joke.
good luck!
you can also test your thermostat by putting it in a pot of boiling water.
driftneil
And It wouldn't be anything else, like a clogged rad or something. I've used that radiator stop leak recently, would this do it?
Salem240
Car: '05 Pathfinder 4X4 SE
'98 240SX SE
Is it possible the thermostat is stuck open.
