Weird oil pressure problem??
z3290dett
Car: 1990 nissan 300zx TT
i just noticed my oil pressure gauge goes to 0 when the car has warmed up, but its perfect when the car is cold... anyone know what could cause this?
es.biggs
Car: 1990 300ZX 5sp NA
get a new oil pressure sending unit. It's easy to install with the oil filter off. I would NOT run my car with the oil pressure gauge reading 0.
z3290dett
es.biggs wrote:get a new oil pressure sending unit. It's easy to install with the oil filter off. I would NOT run my car with the oil pressure gauge reading 0.
thanks man. i'll try an oil change first i just noticed oil smells like gas from flooding before.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
you can hook up a mechanical uage to verify the reading, if you still have low oil pressure it's either a clogged pickup form a denten pan (common in pallet motors) or worn rings and bearings
NORCAL300ZX916
Car: 91' 300ZX 2+2
lol i went through like 4 sending units. the original from both my motors a wrecking yard one and a new one none of them work lol but oddly the oil pressure came on when i had a loaner ecu in while mine was getting remapped, but went off after about 5 mins i just gave up too ha im just happy having speedo and tach cuz after my jdm swap i had nothing. it was probably pre-existing since i bought it with a blown motor.
z3290dett
evildky wrote:you can hook up a mechanical uage to verify the reading, if you still have low oil pressure it's either a clogged pickup form a denten pan (common in pallet motors) or worn rings and bearings
i did a compression test on it and got 150psi average on cold engine, so i dont think its the rings, i'll check to see if there are dents in the pan, its a non swap engine from what i know so..
z3290dett
NORCAL300ZX916 wrote:lol i went through like 4 sending units. the original from both my motors a wrecking yard one and a new one none of them work lol but oddly the oil pressure came on when i had a loaner ecu in while mine was getting remapped, but went off after about 5 mins i just gave up too ha im just happy having speedo and tach cuz after my jdm swap i had nothing. it was probably pre-existing since i bought it with a blown motor.
4 sending units!! LOL
NORCAL300ZX916
Car: 91' 300ZX 2+2
yea i figured they couldnt all be bad especially the new one so i just gave up!
z3290dett
oh yea and it idles high to. it idles at 1,500rpms
evildky
06 Nissan 350Z GT
z3290dett wrote:oh yea and it idles high to. it idles at 1,500rpms
probably the air regulator
NORCAL300ZX916
Car: 91' 300ZX 2+2
might need to clean the throttle body
