SoCalS14 wrote:First....There seems to be a ticking noise, upon acceleration, from 2500 through 3500, coming from the driver side of the car...Its weird because it fades off at 3500 and ONLY occurs between the range I stated and CAN'T be heard if revving in neutral, only under load.
I believe this could be an exhaust leak. What you might be hearing is actually exhaust gas pulse, which sounds like a ticking noise.
I'd check the gaskets/connections from the turbo down to after the cat.
I could be wrong though, plenty of things could make a ticking noise.
