Acecool »
https://forums.nicoclub.com/acecool-u46759.html
Sat Aug 30, 2008 4:32 pm
Ok, I have this weird noise, sounds like a bearing or something... RB20DET
Noise occurs when: Car is rolling, with the clutch pushed in... Also when the car is stopped, when it is in neutral and I let go of the clutch...
If the car is not rolling, and I push in the clutch, the noise goes away...
I replaced the throw out bearing, but they ended up giving me the wrong one (a few MM too long) so the noise was still there, and the clutch would slip under heavy throttle... but it worked fine for normal driving on or off of the highway...
So, I look the engine out again, and am gonna have a friend give me his opinion but yeah, I am lost...
I spun the input shaft of the transmission while the car was off and didnt notice any strange noises, also the pilot bushing on the engine where the input shaft from the transmission slides into is not budging... I stuck my finger in to see if it had play but it is in good condition...
Right now, I am thinking it was the long throw out bearing, and the old one going out... maybe the clutch, but does anyone have any other ideas?
