Weird noise
chill13136
Car: 02 pathfinder LE
Hi all. I am noticing a weird noise only when shifting the steering wheel a little or turning. It kida sounds like gears grinding. But there is not sound when i am going straight. Any ideas? Thanks.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Welcome to NICO!
It could be something like a wheel bearing or something along those lines...
Sounds maybe like a crunching noise??? It could also be something likea CV shaft...
chill13136
if this is a wheel bearing or cv shaft, how much am i looking at for replacement? The noise sound more like when you are grinding a gear with a manual transmission. Also, could this have anything to do with a low level of power steering fluid or possibly a bad pump? I am going to the mechanic tomorrow, so i guess we will see. Thanks.
