weird noise???? suggestions are welcome
Mychal
Car: 89' Nissan 240sx
I have a 89 240sx and i was wondering if anyone might could tell me what this noise is......
when i turn the wheels left or right it makes a kinda squeak noise, its louder turning right than left
only does it when i turn my wheels when im stopped, not when im rolling and making a turn
sounds like its something that needs to be greased or lubed but ive crawled under and cant find where its coming from
any suggestions will be great thanks
Mychal
please....... anyone?
Mychal
bump
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
You could have a dried out balljoint or tie rod end. Check your strut mounts also.
Mychal
thanks broat least someone is helpfulthe bushings r dried out lookin i know that muchdo u know a good source for polyurethane bushing upgrades?
sx moneypit
1986 Toyota MR2
Energy Suspension.
Valett85
Car: nissan 240sx se (93 240sx se and 95 240 sx se)
sitting still puts a ton of strain on your steering. sure it isn't your power steering? at what point does the noise occur. all the way through or once it gets all the way and then you bump it past where it wants to go?
Mychal
it starts whenever i move the steering wheel period (all the way through). idk if its the power steering bc it turns smooth and when its fully turned it does squeal or anything. i forgot to mention its the original suspension and the body has over 200,000 miles
it rides fine, actually pretty good.i just wanted to find out what it was so if its something major maybe i could catch it in time
sx moneypit
1986 Toyota MR2
Place your hand on each ball joint and tie rod end and get someone to turn the steering wheel,you should be able to feel if they are not rotating smoothly.
