weird noise in my engine bay
chalmer240sx
Car: 1990 nissan 240sx
i drive a 1990 nissan 240sx and last night i heard this really weird noise under the hood and after i started to let the clutch out. the noise only does it on decelleration im not sure what it is. any ideas? its a fast rattleing noise
Ignoble
Car: Onevia, Sileighty
Might be something loose? Heat shield on catalytic converter rattling due to vibrations? Transmission gears vibrating due to thin gear oil? Throw out bearing gone bad? Not too sure but just throwing out stuff.
Vegascorbin
Car: 1990 240sx dirt track race car
Not much to go on but I have to throw out the idea of timing chain and guides.
Have you done anything to the engine lately?
chalmer240sx
we figured out what it was. my fly wheel fell off due to the fact that when we did the 5-speed swap we used the automatic flywheel bolts.
thanks for helping though
IF U DO A FIVE SPEED SWAP DO NOT USE AUTOMATIC FLY WHEEL BOLTS
IT WILL COME OFF AND POSSIBLE STIP OUT THE THREADS IN THE CRANK CASE
