flawscow »
https://forums.nicoclub.com/flawscow-u155503.html
Fri Mar 05, 2010 7:29 am
Hi All,
My first post here, so please go easy on me if I don't give enough info. I have a strange noise coming from the front of the vehicle, I believe from the passanger side. It's almost like a muffled creaking. It only occurs when the car gets into bumps (small or large) while I am pressing down on the gas pedal. If I am not pressing down on the pedal, and roll over the bumps, there is no noise.
I took the car to two dealerships, one in PA, one in NYC. The one in PA couldn't find the problem, the one in NYC said something about my front axle needing lubrication, and wanted to charge me $280. I don't really believe them though, since if the axle indeed needed lubrication, the noise would happen all the time, regardless of whether I am pushing down on the gas pedal or not.
I read about the engine mount issues here, and when I went into the dealership, I asked them to check it. I don't know that they did though, they just came back with the axle lube price tag.
The second thing is, they said my battery needs changing. Now I have an 08 2.0 Sentra with 16,000 miles on it, how on earth do I need a battery that early?!? If I do, shouldn't it be covered by the warranty? They wanted to charge $60 for the battery.
Do I need to find me another dealership? What's going on?
Modified by flawscow at 10:48 AM 3/5/2010
