sooner4x4 »
https://forums.nicoclub.com/sooner4x4-u71453.html
Sun May 01, 2011 12:14 pm
The description of "loud", "screaching", "clicking", with brakes sounds like more than just pads worn down to the wear indicators. I have had these same symptoms with another car, and when I looked at the front brakes, I discovered one of the caliper pins had broke, more accurately the threaded portion of the caliper pin had stripped out. This allowed the caliper/pad assembly to get crooked against the rotor. The rotor was destroyed, and if left to go much longer would have resulted in a catastrophic failure of something. Please don't ignore this. If it is just pads, that would be good (less expensive), but don't make that assumption given the noises you are describing.
This is very easy to check yourself, if you are comfortable with removing tires and doing basic maintenance yourself.
