jonja wrote:k, so i hit the starter with a hammer and now it works. bad solenoid? any way to fix that without removing the starter?
Disclaimer: I have not removed a starter on these cars.
However not likely that you can do ANY starter repairs on any starter without first removing the starter except what you have done, BANGING with the hammer. Perhaps breaking loose the nut holding the hot lead to the solenoid which may be corroded and clean around there.
Your story reads like an "old starter" and they do accumulate dirt and debris within which might interfere with the solenoid and the brushes. My experience with Nissan starters is positive, meaning they are excellent starters, and worth the effort at restoration. You can replace the brushes if needed but usually a little sanding with fine emery cloth around the commutator will take care of that. There are many parts though and you should proceed with care if you do decide to open it up, but, it is doable. A good parts display, such as contained in the FSM ,will do wonders if you get lost.
From what I have read, here on the boards, is that the removal of the starter from the engine is quite the chore for the novice. You might do a further search for more opinions.
Good luck. Jack
