Suicide.Veteran »
https://forums.nicoclub.com/suicide-veteran-u38572.html
Wed Sep 20, 2006 8:14 pm
OK, so I just KA-T'd my 240sx. Setup is: t25 7.5 psi recirced, 370cc injectors, walbro pump, and a N60 maf till i can get my PLMS kit in.
My problem is a high idle and runnign rich with the distributor all the way CCW I think to be at 20 BTDC and dieing when the bov opens. The car is running at 20 vac at idle and Ive checked for leaks. TPS is in spec, IACV is new, plugs are NGK BKR7E's and new, FPR is good.
IACV hose blew off at one point. Could that have damaged my maf? Havent bothered with pulling the dist yet cuz its a pita to do and I havent had the time. Could it have jumped somehow? I took the guides off so there is only the tensioner. Anything I could be missing?
Need help, I wanna play at 10-11 psi!!!!!
