SR20Essex »
https://forums.nicoclub.com/sr20essex-u41694.html
Mon Oct 16, 2006 3:52 pm
I have an S13 240 with an S14 SR20det in it. Since I had the swap done I get this loud moaning noise when I push the clutch pedal in. Up until about a month ago (the swap was done a year ago) that pretty much remained the only drivetrain problem. when the swap was done I had them put a new exedy clutch in.
Now I get this mechanical gear noise when I don't put the clutch in, and gets really, really loud when I do. And I get a new funky grinding vibrating dragging noise when I use gears to slow the car, and only slightly less bad when I take the car out of gear and just coast. Either way its very loud vibrating moaning noise that makes it very annoing to drive.
Ive checed all bolts on the driveshaft, checked halfshaft bolts, I have a brand new center bearing, put redline MT90 in the transmission 6months ago, and redline MT90 in the used open differential 2 months ago.
I also replaced the clutch master cylinder, slave cylinder, steel braded clutch line.
My question is; does this sound like a major transmission problem or could it be something small like a throw out bearing or something of the like?
I mean would a throw out bearing cause all this racket and vibration?
