weird lights issues!
akalex
Car: 89 240 coupe sr20det
Yess i tried to search!
My girlfriend was going shopping yesterday and got pulled over.The cop told her that all the tail lights (evreything) but the third brake light were off! So i cheked for an hour and it seems that if the runing lights are off the tail lights all work propelly! But when i turn the headlights on evrything go offand if it works when i touch the brake evrthing shuts down exept the third light(window)!
I dunno whats happening but looks like i need some help!1989 240sx coupe with sr20det..
onosqv
Car: '92 240sx Vert
Could be a lot of things.
When my car was having weird problems like that (happened in series) - it was one of the following:
- one of the sidemarker or turn signal lights (front & back) were bad- one of the grounds on the taillight housing were bad - if you take out the plastic piece that holds all the bulbs, you can see where the ground wire touches the plastic; over time plastic melts and messes up the ground - gotta unbolt it, clean it off, and reattach
- are your dashlights out too? if that is it, you gotta check the dimmer switch as well (iirc).
akalex
thanks ill try that as soon as my down pipe is back on!
first thing first!
akalex
ok i did cheked evry single bulb on the car!tried search button as well!
The dimmer switch's good i took it appart!When the car is parked with no power at all, if i touch the brake pedal the clock dim as well as my boost gauge! Witch is wired to my cruise controll button! That is some weird stuff!
