Jay97240Sx »
https://forums.nicoclub.com/jay97240sx-u124075.html
Tue Mar 24, 2009 2:21 am
Well i have JWT Ecu, 370cc injectors, stock maf, K&N filter, Greddy Bov, T3/T4 turbo, full 3 inch exhaust, no cats, AEM wideband.
I know if the maf is too close to the turbo it will mess with the maf readings, but this setup has been this way for almost 2 years, the aem i have for about 2 months, but this lean problem just started less than 2 weeks ago. I have changed nothing on the car.
I do have a slight vacuum leak some place around the throttle body, but i have had that leak for months. Also i have been having a ruff idle, i dont know if its related.
Im not so worried about the deceleration lean part of it, its the while cruising lean situation thats really bugs me. It happens at around 2500 is rpm in 4th or 5th gear, ill feel just a slight stutter which i can also hear from the exhaust, and when i glance at the wideband it will be lean of the scale, and if a tap the throttle it bounces back up to the regular 14-15 reading. its as if the car chokes for a second.
Whats becoming more common over the past 2 days is if i gently press the throttle say going 25-30 mph in 3rd gear, the car runs lean for a second then swoops to normal.
Note: i did make a better intake pipe a couple months ago, but everything else is the same.
