Weird KA starting issue.
rxzach93fd
Car: 92 240sx
I have a 240 with a dohc ka that I bought about 2 months ago. The car has run great up untill a week ago. The car will only start if it has been sitting for like 3 hours. If you turn it off and then try to start it 5 min later it just cranks. I replaced the plugs and the fuel filter hoping that would be the issue, but didn't help. Would could this be?
240Kahn!
Car: 93 Hatch
Maybe coolant sensor? Or there abouts. Kinda sounds like it has to be cooled off for it to start
zach-Ka
Car: 1990 240sx (SR)
http://www.frsport.com/Nissan-....html
It helps tell the ecu how much fuel to send to your injectors. If its failing it wont tell the ecu anything.Idk but it sounds about right.
miggs11
Car: 1989 Nissan 240SX, 1993 Nissan Cefiro
Check the coil we had a problem it was the coil that was getting hot and would not put out enough charge to start but would work if it cooled down.
ZiG
Car: 1993 240sx coupe
why dont you check a service manual for "hard to start when how".
rxzach93fd
Car: 92 240sx
i put a new cts in today and Im pretty sure it solved the problem. It has started up every time so far.
zach-Ka
How does it drive now?
rxzach93fd
Car: 92 240sx
it drives fine, it drove fine before it just didn't like to start up
