chad-s12-drift »
https://forums.nicoclub.com/chad-s12-drift-u160421.html
Sun May 16, 2010 11:58 am
so my motor has been in and running great for like 7 months but just recently on 2 very hot days after driving for like 30 or 40 min it would start running s*** sounds like its on three cylinders the first time it did it i pulled over made sure nothing was loose took the coil pack cover off and turned the car off and on a couple times and i was still running like crap so i just putted home and let it sit like 15 min with the hood open and cranked it and everything was fine it didnt do it again until yesterday about a week from the first time again a hot day it started to do it on the freeway so i got off popped the hood checked all connections and took the coil pack cover off again turned the car off cranked it and it was fine so i continue to drive home and it starts doing it again about 10 min later turn the car off at a red light start it to go and it was fine then it did it again so 3 times in this one 40 min trip this time i oull over pull the hood latch and it quit so i close the hood and drove the last 5 min home fine my guess is something is overheating maybe electrical like one of the coil packs cutting out i have no clue tho do our coil pack tend to over heat? or any suggestions. the symptoms while it is doing it are no power i can barely get up to speed and it sound like 3 cylinders
