cOrPsE »
https://forums.nicoclub.com/corpse-u48584.html
Thu Oct 09, 2008 5:23 pm
Ok, so i have kind of a weird problem. This is how it started i was driving in the rain and all of a sudden my car started running weird. Backfiring and not letting me rev past 3k. Then a minute later it stalled and wouldnt start and when i pulled the key out of the ignition it stayed on, and the EGI relay started buzzing. I pulled the EGI relay and anouther fuse (i forget which one sorry) and then my ignition shut off. It actually re-started and i drove it home with no lights on or anything. (it was running of the battery) then we i got close to my house it started like not letting me give and gas and stalled and i rolled into my driveway.
So a power wire from my old sub/amp was sitting in water. I didnt do anything with it i know its my fault. now i removed it out of my car.
So since it was running off the battery for a bit i checked the alt and it was fine. Its not running off the battery now but its also not running right now i fixed it for like a day and had the same problem happen. Exept it didnt re-start someone had to give me a jump. Now the check engine light is on.It wont turn over unless a put a wire from the + side directly to the starter and it will just turn over not start.
EGI has something to do with fuel delivery i think... idk im a noob please any help would be nice
Just something to look at =(
Modified by cOrPsE at 8:49 PM 10/9/2008
