JoeKansas »
https://forums.nicoclub.com/joekansas-u24701.html
Tue Jan 18, 2005 7:37 pm
The carb cleaner spray won't be "helping" the problem, it just helps you detect leaky intake gaskets. If there is an intake gasket leak, the carb spray will get sucked in this leak and noticably change the way the engine runs- enough so that you will notice it right off. Get enough carb cleaner in there at once and it would make the engine sputter and die- if you don't throttle the engine up real quick and make it come out of it......
