Weird Idle
NoStickDrift
Car: 1989 240sx
I know there are tons of stuff on the idle of a 240sx, And I have searched. But mine seems a bit different of a problem. So here it goes. My 89 when in park idles fine about 700 - 800rpms. When in drive wth my foot on the brake its at 550 - 650rpms. And it fluctuates pretty bad sometimes. If i turn the AC on, it will idle at about a constant 950rpms. Why would it be constant with the ac on, and not constant with it off. Also it was doing this before I installed a cone intake, but its a little bit worse now. Any suggestions would be helpfull.
NoStickDrift
Car: 1989 240sx
Comon guys I need some help hear, some of the techs at my shop said it could be a vac leak, any thoughts?
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
Sounds like a sensor problem or sensor wire problem.
yangs13
Car: 1993 240sx-Dead, 2001 Maxima
if it starts to idle really rough and at low rpm, it could be one of your fuel injectors. when my car started to idle rough and the engine would shake violently, i took it to a local shop and had dianostics on it, it turned out to be a bad fuel injector.
