L36 »
https://forums.nicoclub.com/l36-u195655.html
Mon Nov 03, 2014 4:02 pm
Its entirely random. It can start just right after starting or occur sometime after it runs for a bit. Mostly the occurrence is random. The slowing down is not significant, were talking 200rpm drop and back to normal idle, rinse and repeat. Sometimes it does one dip and does not occur for some time, sometimes it goes back to back. In neutral it happens but not as frequently when in park. Only reason i bring the alternator is because Ive seen similar issue due to faulty alternator clutch. In park and neutral the engine is getting less fuel and once you put the car in gear the fuel to air ratio gets richer thus the engine has bit more power so it does not bog down as it would in park. I'm going to fill the car up with 93 tomorrow and throw a can of seafoam into the tank and see if the issue improves.
