SunshineAcid »
https://forums.nicoclub.com/sunshineacid-u11570.html
Wed Apr 13, 2005 11:06 am
history: had a rusted out 91 (guy drove to michigan all the time =\)while doing maint. on 91 i put 3 fingers *through* the frame. so...bought a blown 89 for 150 bucks (great body, hole the size of a pancake in the block itself)swapped the de into the e chassis91's engine ran fine before swap (was auto, 89 is 5 speed)did not mess with sensors, or change idle setup in any way/shape/formfirst started the de with no problems, im very confident about the wiring, we traced *everything* and even the diagnostic plug works, nothing was left unchecked/unhooked/cut)heres the question: when i start the car, it revs up and holds about 1k to 1.1k rpm and is a bit sporratic (sp?). it will stay like this until i turn teh car off, no matter how hard/soft i drive it, or ambient temperature. the reason i dont change it, is because after i drive the car and let it fully warm up, and turn it off, then start it up again (like going to a gas station) it idles perfectly. bout 775 rpm (i set it a bit high intentionally, as i think it sounds better and doesnt vibrate nearly as much)ive read up and and i think ive narrowed it down to the idle control sensor, the water temp sensor and the o2 sensor.i dont think its the o2 sensor, as my last tank, i got bout 18 mpg in the city (and i do have a bit of a lead foot)i dont smell the richness that a lot of nissans put off.but if it were the water temp sensor, wouldnt my readings in the cockpit be off too? i mean on the instrument panel, if my temp sensor was faulty, wouldnt my needle show it? unless that is on a different temp sensor (i know there are at least two of them =P)just trying to troubleshoot, if anybody has any .02 let me know pleasethanks in advance
