Pwnin O'Brien »
https://forums.nicoclub.com/pwnin-o-brien-u136941.html
Thu Mar 11, 2010 10:50 am
I need help!!!
So the hissing that I originally thought had disappeared had not actually disappeared. I have had the hissing noise for the past 8mos. or so, I just ignored it. I recently had to remove the intake and throttle body to do the throttle body bypass and I figured this would be a great time to get rid of the hissing for good. My solution was to use some RTV gasket maker instead of the gasket from the dealer. The gasket maker went on well and there were no visible gaps. Once I put everything back together and revved up the engine to test for the leak I couldn't hear any hissing anymore, so I figured I fixed the issue.
Well, when I started to drive the vehicle I noticed a new sound. There is a louder whistle coming from under the hood, but this whistling is different from the last one. The last whistle would get louder as the RPM's increased, sounding like a vacuum leak. This new whistle is not dependent on RPM's, it is dependent on the accelerator pedal position when the engine is under load (the issue does not happen with the vehicle in neutral). When I hold the pedal in a certain position the pitch of the whistle will change, as I push the pedal a little closer to the floor the whistling gets deeper and then goes away as I push the pedal further. The whistling sound only happens when the pedal is at this specific position. There's a very small amount of pedal travel in where it will make this whistling sound. The whistle is so loud it can be heard very easily in the cabin with the windows up.
At first I thought maybe the throttle body cleaner I used to clean the throttle body before re-installing it may have somehow fouled up the electronics in the throttle body. I don't have any DTC's but I doubt I have driven the car enough to register one yet. Also, I listened to the throttle body during the power-down cycling (when you turn the vehicle to OFF the throttle body will cycle completely). I heard not strange noises when it cycled so I am assuming it isn't the throttle body electrical motor.
I thought maybe it could be a different vacuum leak but what vacuum changes with the accelerator pedal position? I could see it changing with the engine RPM's but not with the pedal position.
I really have no idea what this noise is and I could really use some help with this one. If anybody has any ideas please let me know, I'm up for anything!
