Weird headlight problem
elpiar
Car: 1992 KA-T
Just bought my z32 (1991) for $500
It's literally trashed though, as far as the interior goes. It's really neglected.
There is something really weird about the car. The headlight is always on high beam mode, and when I brake, it changes to low beam. When I release the brake pedal, it's back on high beam.
The ghetto guy must have been messing with it?
300freekzx
Car: 1990 300zx N/A, 1992 Honda Accord LX , 1991 Honda Accord LX, 2006 M35 Sport
sounds like wiring probs.
Jaykit
Car: 1990 JDM Fairlady Z32, Twin Turbo, 2+2, Silver
Most likely a wiring problem. Try turning off and on your fog light switch in the dash. When I have the switch off, my lights auto go to hi-beam and when it the switch is on, then I can flip between low and high. Just the way that it was wired I guess.
elpiar
Car: 1992 KA-T
I tried turning off and on my fog light switch, it doesn't have any effect.
fairladyz1990
Car: 2004 Subaru STi Lightly Modded and 1992 Nissan 300zx Twin Turbo
Somebody tried to play shade tree machanic with the wiring and somerwere along the way, I would say after alot of alcohol, the guy who had the car before you screwed up the wiring... PS look for alot of sticky electrical tape and cheap connectors, thatll realy tell you if some one played with the wires..
elpiar
Car: 1992 KA-T
Yea I've been looking for those, but so far no luck yet. I have removed a whole bunch of alarm and remote start wire jumbles (no one has the remote, of course) suspecting that was the cause. But it's not.
T45
Car: King Kong powered Z32
Is the battery fully charged? Low voltage does some really wierd stuff in these Z's.
fairladyz1990
So you might actualy just have a crazy short somewere, like the post about the low battery, Z's tend to do some crazy things when you have abad short, bad grounds, loose terminal, bad connections, etc..... Its gonna be a long drawn out process, but I would say get a voltage tester and test all main leads and what not..... Good Luck
