Well that's exact;y what mine was doing and got worse over time. First it was just the driver's side, then the passenger's then both @ midnight while cruising down the 405 freeway. At first I though it might be the ballasts going out which is not cheap to replace OEM. I replaced the switch and now everything is back to normal.Mischi wrote:Thanks. I had seen this before about the switch but I thought I would ask because they both don't go out at the same time.
Did you ever get this fixed??? I am having the same issue! I'll turn the lights on and left is on and the right is off, cycle the light switch and its vice versa????Mischi wrote:Thanks. I had seen this before about the switch but I thought I would ask because they both don't go out at the same time.
Is it Canadian...does it have DRL's?rsweeten wrote:Did you ever get this fixed??? I am having the same issue! I'll turn the lights on and left is on and the right is off, cycle the light switch and its vice versa????Mischi wrote:Thanks. I had seen this before about the switch but I thought I would ask because they both don't go out at the same time.
