silviasgp06 »
https://forums.nicoclub.com/silviasgp06-u61439.html
Sat Mar 28, 2009 8:23 pm
first time ever i set timing by:
1. clip timing light pickup to the exsposed wire on the harness.2. aim gun at timing marks and set according to FSM
the time where this error occurred, I set timing by:
1. pull the #1 coil pack off2. put a spare spark plug wire on the #1 plug, with the other end connected to the coil pack and attached a ground wire to the coil pack.3. clip the timing light pick up to the now installed spark plug wire4. aim gun at timing marks and set according to FSM
before setting timing on the second occasion it read 15* retarded with the spark plug wire installed, and the timing light clipped to the cable/wired installed between the coil pack and plug. I how ever did not compare the reading between the installed wire and the exposed factory wire.
