Altiman94 »
https://forums.nicoclub.com/altiman94-u8148.html
Tue Jun 29, 2004 4:27 am
Well I just got my 240sx back from the mechanic getting new valvec seals put in and a new problem has arised. Here is waht it does:1. Everytime I downshift my radio will turn off, somtimes just when im driving down the road2. Tach doesnt start working till car is revved past 1500 rpms. 3. Headlights wont go down or up when car is not running, no accesorries work when car is not running actually.4. Weird 'ticking' noise in the interior of the car. Sounds liekit is coming from behind the gauge cluster. Most prevalant when at idle and on the breaks, but it is not brake related at all.5. Mechanic checked it out and said my fuse for my alternator under the hood was blown. I ordered a new one from nissan, he said i was not getting charge from my alternator but that it was running off battery power instead. Should this new fuse fix all these problems?
Also, would bad fuel injectors cuase a rough and inconsitant idle? iI have both symptoms but I do have 4 new ka24e stock injectors on their way to me. Im hoping this fixes it as i have replaced the cap, rotor, and plug wires. As well as the coolant temp sensor.
