Weird electrical problem
ralphsdiorama
Car: 1991 240sx, 1998 240sx (RB project)
So I just completed my sr20 swap and everything was running smoothly. Then while I was driving I noticed my emergency brake light on the dash was twiching and there was an electrical buzzing coming from underneath the driverside dash. Then a short while later the car stalled and the battery was dead. When I charge the battery and hook it up I can hear strong electrical buzzing noise down underneath the driverside dash. Any clues to what could be causing this electrical short that is draining my battery?
rkreimer10
Car: s13 240sx with sr20det
a little more info would help?????? who did your wiring? is your battery located to your trunk? i would have your altinator tested and also check your wires that hook into your alt.. if your hearing buzing and lights are flickering then you most likely have a short. time to get out the volt meter. electrical problems suck. recheck your whole wiring harness. it sounds like it might be the conection that is in the dash behind the glovebox. but seriously when it comes to electrical it could be one of a million things.
