puck »
https://forums.nicoclub.com/puck-u45228.html
Thu Nov 19, 2009 5:53 am
In case anyone is interested, I did fix the problem without tearing the dash out. The good news it was a relatively easy fix. The bad news is I can't really explain what actually went wrong because I did not take the dash apart. My best guess though is that when I cut the wires the the connector that goes to the power assembly, I did all of them at the same time. I believe I shorted the circuit and a fuse or another protective device tripped (that is not documented in the FSM) or, perhaps, a portion of the wire melted. I'm fairly sure this is what happened because the green/orange wire never gave 12 volts after I cut it so something was wrong long before I actually hooked up the new assembly. Lesson learned, only cut one wire at the time and disconnect the battery before hand (both of which I knew but in my hurry to finish decided not to).
In any case, to get around the break in the circuit I spliced a new wire into circuit 13 (backup circuit) after the fuse under the dash. Thus the circuit remains entirely behind the intended fuse. I ran the new wire to the trunk and connected it to the green/orange wire which is also part of #13 (backup circuit). Essentially, I just bypassed the break in the circuit without tearing out the dash. Everything seems to work fine now, including the non-OEM power antenna assembly, wireless remote, clock, ect, ect. If anything goes wrong as a result of this configuration, I'll post about it but things are looking good.
Modified by puck at 12:16 PM 11/19/2009
