texasoil »
https://forums.nicoclub.com/texasoil-u1000.html
Fri Nov 04, 2005 12:33 pm
I think it may be either the 'relay' in the drivers door or the 'computer box' in th edrivers door. The FSM has a VERY extensive self test/diagnosis procedure for this complex digital system. The system involves at least 5 different computers (boxes), a LAN, fiber optic data transmission,etc. LOTS of things CAN be the cause, but usually its a bad connection or switch somewhere. My '94 has the exact symptoms. The windows work at the individual doors, but not at the center console. Only driver door opens/locks with either the remote or door button. Seat and steering positioner work. The "failure' started 18 months ago--if keys were left in ignition--it would sometimes lock itself!. Then driver side rear door window would not/would work. The driver side rear door lock would not open -but would lock. Then one day a couple of months ago- the right side disappeared--then came back. Then..,..... its still uncooperative.
Clock is NOT part of this system BTW and its problem is elsewhere--maybe loose connection on inst cluster)
