FinkenS14 »
https://forums.nicoclub.com/finkens14-u122268.html
Mon Jan 04, 2010 9:25 am
So recently a couple days ago I noticed my RB25 car, bone stock motor and boost, has recently gotten extremely noticeable dead spots and is much slower then normal.
Best way that I can put it is the car pulls great till about 4500, then hits a dead spot, pulls like crap to about 5300ish, then gets a burst of power till 6000, then takes forever to pull to 7000.
During the dead spot from 6000-tooo the car does have a slight pop.
Things I Know:The clutch is not slipping.New plugs, coils, and ignitorTiming is goodCompression is goodDone a leak down test, came back good.Has good gas in it, 91OCT, highest you can get at the pump in colorado
Things Ive Recently Changed:
Got a stock bumper on the car, and when I did this the IC had to be moved back. When this was done my cold pipe sits at a really odd angle in the coupler that is attatched to the front mount itself. Maybe I had an extremely small boost leak?
Things to think about:
Car has a really random idle. Sometimes itll sit at 1500, sometimes itll sit at the regular 750. Cant figure that one out. Running no t-stat with a stock KA radiator, thats the reason for no t-stat.
So anybody got any ideas? My next thing im going to do is check for that boost leak issue, and see if I have any torn couplers, or loose clamps.
Thanks guys.
