01Blackerado »
https://forums.nicoclub.com/01blackerado-u84167.html
Sat Jan 05, 2008 11:27 am
First thing you should try doing... get a ratchet and try turing the crank by hand. That way you can physically feel contact of the pistons and valves if the timing is off. If thats ok and timing is good then the next thing I'd check is wiring!!! Cam sensor, crank sensor, fuel injectors, etc. If wiring is all good then you need to check the rest of the mechanical parts of the vehicle. Alternator, starter, battery, coil, wiring (not saying you did this wrong but just suggesting....wiring order for firing)
Let us know how it's coming
