clovers525e »
https://forums.nicoclub.com/clovers525e-u47904.html
Wed Feb 21, 2007 5:33 pm
so, my friends just baught my brothers 240 and he is having some weird problems out of it. its a 90 s13 with a 95 s14 motor. when he first got it it didnt seem to have too many issues overheating. of coarse we wouldnt know since the temp gauge was never wired up corectly, along with the tps and a bunch of other things but thats besides the point. he drove it about 45 minutes the other day and called me saying it wouldnt hold an idle the water pump was smoking and sizzling. two days after he got it, it started taking alot of water, he would fill up the reserve tank and it would be empty the next day or after he drove it or not, didnt make a difference. there was a little water on the ground but not as much as it was loosing. we replaced the water pump and thermostat the other day because what water was leaking out seemed to be comming from around the main pully. now when he drived it a little the overflow tank bubbles alot the top of the radiator is really really hot, the center is not even luke warm. the exhaust gas doesnt seem to be any abnormal color (ie white, whitish blue, pink, whatever) so, thats about it. where going to replace the lower radiator hose because there might be a coolant leak there (probably not or if at all a very small one) and where going to install my water temp gauge to see if that gives any help too but if anyone has any ideas that would be fantastic. should we pressure test the coolant system? i'm going to give him a new rad cap i have off my s14 too.
