Krew126 »
https://forums.nicoclub.com/krew126-u140567.html
Wed Feb 03, 2010 7:28 am
Ok, so after about 5-10 minutes of driving my car, it will sometimes start to idle higher at stoplights and take a little while to come back down.It only does this if you drive it for about 10 minutes. The car will start to idle at 1,000 rpms or a little over.Also, say I'm cruising in 4th at 40 mph, and I put it in nuetral not giving any gas, the car will slowly raise the rpms and then about a second or 2 later it will come back down to 1,000.
Now you ask, what does this have to do with cooling?Well, when it runs like this if I turn the car off and get out, I will have coolant rushing into my overflow tank with the smell of burning coolant when you open the tanks cap.
Keep in mind, this only happens sometimes which is why I have no clue what it is. And when it runs like this, the temperature gauge shows no signs of overheating at all. If anybody could help I'd really appreciate it, thanks.
