Bosrudorfer »
https://forums.nicoclub.com/bosrudorfer-u32632.html
Mon Jun 26, 2006 7:30 am
Weird coilovers problem
On the front driver side sometimes (it usually is fine and doesnt do this) but when I turn the wheel I can hear (and from looking at it see) the spring turn in the direction the steering wheel is being turned and then as the steering wheel is moved the opposite way the spring (as if tension is being released) pops back. It makes a booiinng sound. I have about a half finger gap between the coilover and rim/wheel so I dont think the they are touching... what could be causing this.
My first thought was that the tire might be grabbing the spring and turning it as the wheel turns....
The passenger side is fine and has never had this problem...
Thanks
