Krew126 »
https://forums.nicoclub.com/krew126-u140567.html
Wed Oct 21, 2009 2:19 pm
Okay, so I just bought some used Megan Racing Street Coilovers, and they have been making a weird noise. The noise sounds like its the spring moving slightly, and it's only coming from the front right. If this helps any, it sounds kinda like a ding or a pop, not neccesarily a pop but like pressure is being let off it. It also only makes this sound when going slow like turning out of the driveway and usually with the wheel being turned to the left.
Although I am hoping that I figured out the problem, which I think could be how the locking perch is set on the front right (The sound only comes from the front right).
I am new to coilovers, but to my knowledge, looking from the spring down to the last perch, it should be:1)Spring2)Perch3)Perch4)Threads5)Last perch
All of the coilovers look like this except for the front right one. This one goes:1)Spring2)Perch3)Threads4)Perch5)Perch
I was just wondering that if I set the middle perch just below the first perch, would it make this sound go away. If anybody has any other ideas, please chime in, and thank you for whomever may read this wall of text.
