Weird Clutch, Transmission Problem.. HelP!
xxmarcusrxx
Car: s14
So I bought an exedy stage 2 clutch kit. Kit # 06953A. I put it in my 97' s14, since then the clutch fork has ben loose on the pressure plate. Like When everythings bolted up, I can move the fork back and forth a little. I didn't think much of it untill I went through 2 slave cylinders, they were over extending and blowing up on me . It seems like my slave is extending way too far to engage the clutch. Its basically fully engaged after I bleed the clutch. I did get the flywheel resurfaced, Is there such thing and grinding it too low?
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
i would check to see if your clutch fork is bent...
g35paul
Car: 08 Acura Tl type S, s/c 03 g35 coupe and s13
i just had this same problem on my stage 4 clutch... it ended up being way to much pressure in my lines and not letting it fully disengauge.... i ended up pushing my throw out bearing through my pressure plate.... thank god i had extras laying around..... anyways, all i had to do was readjust my pedal.... just loosen the bolt on the clutch pedal on then turn the long screw coming from master cylinder with your hands....
ii went through 3 new slaves and was even bout to just cut the pin for the slave.... the i asked my mechanic and he knew right away...lol
jetroy240
Car: S13, AE86
I would check the clutch fork condition & installation, probably not fully hooked to the fulcrum.
xxmarcusrxx
Car: s14
Thanks Everyone for your Inut, I'm sure it will help someone
xxmarcusrxx
Car: s14
g35paul wrote:i just had this same problem on my stage 4 clutch... it ended up being way to much pressure in my lines and not letting it fully disengauge.... i ended up pushing my throw out bearing through my pressure plate.... thank god i had extras laying around..... anyways, all i had to do was readjust my pedal.... just loosen the bolt on the clutch pedal on then turn the long screw coming from master cylinder with your hands....
But my problem is that there is a gap,so I would have to extend the pin if anything. I have like 3 pins so I might take two and weld them together to get that 5cm of space i need. I'm going to check theclutch fork and see if it's bent tomorrow. I'll let you all know what's going on.
Jables
Car: 1995 RB26DET S14, 1991 RB25DET S13, 1992 S13 LS1 Coupe
When everything is bolted up and together how much room do you have between the throw out bearing and the top of the diaphram after its bled?
