Meantime »
https://forums.nicoclub.com/meantime-u7126.html
Thu Jun 26, 2003 7:46 pm
It sounds like the clutch is still lightly touching the flywheel, even while you have the pedal down. Chances are you have to adjust the pedal travel - it may not be completely disengaging the clutch even when it's all the way to the floor. Either that, or you have a ton of air in the line to the slave cylinder and there's not enough hydraulic pressure to get the clutch completely disengaged. Check your free play and pedal travel first, adjust if necessary, then bleed the slave and see if that solves the problem. If it doesn't, you have some sort of voodoo curse going on.
